Auto Redial
Latest smartphone news, reviews, tips, and updates.
smith
Developer
Developer
Has thanked: 4 times
Been thanked: 5 times
Spain
Auto Redial
Unread post by smith »
Auto Redial v6.29 [Mod]
Requirements: 5.0+
Overview: A simple program (dialer) to automatically make calls (auto dial) to a specified number.
The program is designed for automatic dialing to city, long-distance, international numbers, as well as SIP and IP .
The application supports 2 (two) SIM cards (dual sim).
The application has support for scheduled calls. You can specify a schedule for automatic redial with different options.
The program has the following types of schedule:
- once at a specified time and date;
- recurring daily or on certain days of the week at a specified time;
- recurring calls after a specified period of time.
In the application settings, you can enable or disable the speakerphone during a call. (By default, it is enabled).
Also in the settings you can turn on the alert with a sound alert before the start of the call on a schedule.
All required permissions are needed for work the application. The data will not be sent, not collected and are not processed, and used for making calls.
⚙️ Mod Info:
◉ Ads Removed
◉ CPU Arch.: Universal [No Libs]
◉ All Unnecessary Garbage Folders & Files Removed
◉ Multilingual
◉ Optimized & Polished
◉ Mod By Ela Mods
❏ Note:Don’t worry about any detections; all detections are false positives. Just enjoy the mod!
What's new:
Fixed bugs. Created to help make calls. Multiple SIM cards are supported. In this application, you can call on a schedule! Added the ability to minimize the application to Picture-in-picture mode
This app has Credit advertisements
https://devuploads.com/zvsrb7gvhyxn
Return to “Mobile Zone Updates”
